exhuast spit water with starting problem
Old Apr 24, 2006 | 05:39 AM
mnsirx's Avatar
Member
Default exhuast spit water with starting problem
i have a 97 Audi a4 2.8 and have problem starting the car. When I manage to get it started, the exhaust spit water when i floor it. Any idea what is wrong with it? i was told that it might be the head gasket or something but does this affected the starting engine part? Once i got the car running, i have no problem. It can run for hours. i just replaced the sparkplugs but no change.
Old Apr 24, 2006 | 11:15 AM
techbod's Avatar
Default RE: exhuast spit water with starting problem
are you losing coolant? are the plugs getting wet with coolant rather than fuel? if yes suspect head gasket one way to do a quick check is remove the plugs and spin the engine over and watch for water spitting out of the plug holes or get a compression test done
Old Apr 24, 2006 | 06:19 PM
mnsirx's Avatar
Member
i did that but i was hard to tell if it was fuel or water. did this affected the starting engine part? i dont fine having water in engine can give the engine a hard time starting. thanks
mnsirx
Jan 4, 2011 03:29 AM
collinedward
Nov 21, 2008 03:37 PM
collinedward
Nov 20, 2008 01:23 PM
