Failed Coil Pack
Old Oct 26, 2014 | 11:54 PM
codyayrton's Avatar
Default Failed Coil Pack
Thought I'd share my experience since searching this forum did not turn up my fault codes in the context that they applied to me.
2007 Audi A4 Avant (B7) was cutting out under moderate to heavy acceleration from a stop for a few weeks. No VAG-COM fault codes. Then all of a sudden was running rough and Check Engine Light (CEL) flashing. VAG-COM returns fault codes...
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH14--- Serial number:
Coding: 010C010A190F0120
Shop #: WSC 06335 000 00000
VCID: 2E531157B9261D6E391-807B
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170664 km
Time Indication: 0
Freeze Frame:
RPM: 1127 /min
Load: 53.7 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 24.0°C
Absolute Pres.: 890.0 mbar
Voltage: 13.589 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170664 km
Time Indication: 0
Freeze Frame:
RPM: 1277 /min
Load: 52.1 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 24.0°C
Voltage: 13.843 V
Readiness: 0110 0101
The "Random/Multiple Cylinder Misfire Detected" had me thinking it was a problem not specific to one cylinder. I used the Bentley manual troubleshooting and wasted half a day trying to figure out what global problem would cause multiple misfires. Re-gapped plugs, cleared fault codes, started motor, same fault codes reappear. Pulled out the multimeter, checked this and that. And on and on. The Bentley manual worked me into a corner stating that I needed to replace the cam position sensor. This compelled me to wonder why I would start buying new parts before I finished checking other things for free. After wasting all that time, I took the #3 cylinder coil pack and moved it to a different cylinder. This time, the fault code for #3 moved to the other cylinder. AHA! So "Random/Multiple Cylinder Misfire Detected" shows up even when the problem is localized to a specific cylinder. New coil pack less than $30 at Audi dealer. Car runs great.
In hindsight, I wish I had never picked up the Bentley until first trying to switch around the coil packs. It would have been a 15-minute job.
Old Nov 30, 2014 | 04:30 PM
garync1's Avatar
Whats the best coil pack? is it bosh?? the advanced auto and auto zone ones work but. after i switched them to different cylinders problem went away but still comes if you nail the gas pedal down. A 4 turbo. 2007
Old Nov 30, 2014 | 04:32 PM
garync1's Avatar
i would like to order online. so if anyone has a link to a dealer would be great. i want the OEM direct replacement
Old Dec 3, 2014 | 04:19 AM
codyayrton's Avatar
I got original equipment from the local Audi dealership. I think that they are Bosch. At only $30, I wasn't going to take my chances with parts houses.
Old Dec 7, 2014 | 03:09 PM
garync1's Avatar
thanks! i did and now its running great..
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
02DolphinA4
Jun 20, 2007 12:01 PM
ania
Jun 6, 2007 12:44 PM
