A6 Failed ignition coil & exhaust temp sensor
Old Jun 6, 2007 | 11:11 AM
ania's Avatar
Default A6 Failed ignition coil & exhaust temp sensor
I had to get my '03 A6 towed to a dealer because it was miss-firing and the check engine light was flashing. When I got to the dealer thay said that one of my ignition coils failed and my exhaust temperature sensor was not reading right.
Of course they suggested having all 6 coils replaced + the sensor for $950!!!!
Replacing 6 coils would be $450.
I am looking for some advice on what I should do.
Should I really replace all 6 coils, or would 1 be enough (I am worried another would fail soon)
What about the sensor. Is this really crucial?
It is a 2003 2.7T 87K+
Old Jun 6, 2007 | 11:23 AM
techbod's Avatar
Default RE: A6 Failed ignition coil & exhaust temp sensor
coils last a very long time so only the bad one needs replacing, did they do a fault code check? if not they are guessing and the cost will somersault so be aware get them to do a scan and give you the codes then post them here
Old Jun 6, 2007 | 11:26 AM
ania's Avatar
I will ask them for a scan.
Old Jun 6, 2007 | 11:29 AM
techbod's Avatar
dont just ask them - tell themyour the one paying
Old Jun 6, 2007 | 12:28 PM
ania's Avatar
Will it cost me to do the fault code check?
Old Jun 6, 2007 | 12:44 PM
techbod's Avatar
yes unless its covered by a warranty
Taurean Bull
Aug 19, 2009 11:05 AM
CamoA6
Mar 14, 2008 01:01 PM
jasgtr
Jan 22, 2008 12:30 PM
OrientExpress01
Mar 16, 2007 10:43 PM
tartan rob
May 1, 2003 06:43 AM
