front bumper removal how 2
Old Sep 25, 2007 | 12:34 PM
techbod's Avatar
Default front bumper removal how 2
Exploded view of front bumper removal and installation
1-
Cover
q
Removing:
Remove front wheels.
Unfasten front half of wheel housing liner .
Unscrew hexagon collared nuts on both sides.
Screw oval head self-tapping screws out of wheel housing liner .
Unscrew hexagon socket head bolt and pull out cover with carrier to front.
q
Installing:
Note[/align]
Before fitting bumper, press clips into wing .
Retainer tab of cover must engage in clip.
Engage cover in guide .
Tighten hexagon collared nuts
Screw in and tighten combi bolts .
Note[/align]
Height of impact absorber with respect to cross member is adjusted automatically .
2-
Guide
q
Removing
3-
Wing
4-
Clip
q
Retainer tab must engage in clip on installing cover
5-
Wheel housing liner
6-
Oval head self-tapping screw - 1 Nm
7-
Hexagon socket head bolt - 23 Nm
q
Screw in as final step in bumper assembly procedure.
q
Height with respect to cross member is adjusted automatically .
8-
Air inlet grille
q
Removing and installing
9-
Air inlet grille
q
10-
Hexagon collared nut - 6 Nm
[IMG]local://upfiles/12092/571E907F3E094092B7865C8D2A43BB83.jpg[/IMG]
Old Mar 2, 2008 | 08:35 PM
thesmartfarmer's Avatar
Default RE: front bumper removal how 2
ORIGINAL: techbod
1-
Cover
q
Removing:
q
Installing:
Note[/align]
Note[/align]
2-
Guide
q
Removing
3-
Wing
4-
Clip
q
5-
Wheel housing liner
6-
7-
q
q
8-
Air inlet grille
q
9-
Air inlet grille
q
10-
does this supposed to show pictures?
Old Mar 2, 2008 | 09:02 PM
turbo kraut's Avatar
Tech Guru
the bumper once you have actually gotten it off, is like wow how did that take me so long to figure out
but it is 2 bolts behind bumper grills1 per side, 1 screw on each side off inner fender
it helped me to take the lights off........ what i did was push down on the bumper and pull out....... pretty fricken simple
Old Mar 3, 2008 | 02:49 PM
is that with the 3.0 version also?
Old Mar 3, 2008 | 08:43 PM
SAudi's Avatar
im assuming thats for the B6
boettger1
Sep 14, 2013 09:42 AM
fourringking
Apr 2, 2012 05:41 AM
ffdsmokeeater
Sep 16, 2007 12:29 PM
akielb
Apr 21, 2007 05:39 PM
Slowb5
Jan 13, 2006 02:34 AM
