FROSTING ON THE WINDOWS
Old Feb 7, 2007 | 03:21 PM
shootingranny's Avatar
Default FROSTING ON THE WINDOWS
JUST NEED TO KNOW , DOES ANYONE ELSE HAVE A PROBLEM WITH THIER 1990 AUDI IN THE WINTER. MY WINDOWS ALMOST FROST UP ON THE INSIDE. HARD TO SEE OUT WHEN IT'S COLD! IT'S GREAT! ..IN THE WARM WEATHER. THE ENGINE STARTS GREAT! JUST AFTER DRIVING FOR ABOUT 15 MINUTES, THE INSIDE WINDOWS FROST UP. AND I DON'T MEAN SOMETHING YOU CN EASILY WIPE OFF WITH YOUR GLOVED HAND! ANY SUGGESTIONS OUT THERE? THE DEFROST WORKS OK ON THE WINDSHIELD AND REAR WINDOW. BUT THE SIDE WONDOWS ARE AWFULL! MY HUSBAND SAYS I MAY HAVE TO CRACK A WINDOW OPEN SOME.
Old Feb 7, 2007 | 04:13 PM
AWDaholic's Avatar
Senior Administrator
Default RE: FROSTING ON THE WINDOWS
I'm not too familiar with your particular model, but, there should be a couple of vents that (re)direct warm air from teh heater/defroster to your side windows, to help keep them clear. Perhaps those are blocked, internally or externally, somehow? Another think to consider is that your window seals (the rubber parts that surround teh window, when it's rolled up, in case you dint know) may need replacing. Spounds like they're letting cold air IN, which could cause teh moisture in teh air (from all that breathing out you do... if you cud figure out a way to ONLY breath IN) to condense against the cold window and quickly freeze, if the outside air is cold enough.
One last, radical, alternative... Drive Hubby's car. Make HIM deal with teh frozen side windows[8D]
Old Feb 7, 2007 | 04:19 PM
techbod's Avatar
direct the side vents at the side windows unfortunately its common on the older cars ( not that 1990 is that old ) but I think you have an idea what I mean
armyboy91083
Feb 14, 2010 01:44 PM
striker451
Sep 4, 2009 03:44 PM
samantha_audi
Oct 4, 2008 08:39 PM
phillyfan1290
Nov 27, 2007 06:42 AM
cary12
Jan 30, 2006 02:07 AM
