Fuel Problem
Old Dec 8, 2006 | 06:12 PM
A6 Quattro V6 30V's Avatar
Member
Default Fuel Problem
sometime car doesnt turn over any ideas what it might be?????
Anyone know a good mechanic in dallas texas???
Old Dec 9, 2006 | 09:40 PM
dankhound's Avatar
Default RE: Fuel Problem
Does it crank and not start? Or does the starter not crank at all? If the starter doesnt turn you could have a bad battery, bad ignition switch, or bad starter as the most likely causes. If the battery is ok you probably have a bad starter. You will need to remove the connector at the starter and check and see if you get 12v there while someone trys to crank the engine. If you have 12 you need a starter. Otherwise your switch isnt sending the signal to start the car.
MiamiA4guy
Feb 23, 2011 01:11 PM
TurboToughTT
May 4, 2008 09:35 PM
dj_lex
Nov 13, 2007 06:20 AM
hotgue
May 14, 2006 02:08 PM
Joevan
Dec 20, 2005 10:52 AM
