glowing hot catalytic converter
Old Feb 11, 2007 | 10:17 PM
dunnidun's Avatar
Default glowing hot catalytic converter
I have a 97 a4 1.8t w/130k on it... recently i had problems starting up my car. There was a clicking sound each time i tryed starting her up, so i changed the battery. After that it would miss fire like crazy.... finally on, it has this hard shake and if i run the car it only goes about 30mph. Moreover, after about 30min running, the catalytic converter (or what i think is the catalytic converter) starts glowing red hot. Whats going on and what can i do??? Please help!!!
Old Feb 11, 2007 | 11:25 PM
kakarot's Avatar
Default RE: glowing hot catalytic converter
running reach, the extra fuel goes into the exhaust manifold, what is glowing red probably is the turbo. cat is too far.
Old Feb 12, 2007 | 02:28 PM
2k S4's Avatar
Yea, you are running rich. You need to find out what is causing this.
Since you say the car shakes, is it under acceleration? You might have a clogged cat.
You may also have a boost leak.
1. Look for any boost leaks.
2. Find out if the cat is clogged
3. Change out your spark plugs
Old Feb 21, 2007 | 08:58 PM
jbracci's Avatar
if your glowing red hot ur running LEAN not enough fuel it would cause the car to shake to cause its running outta fuel
Old Feb 22, 2007 | 12:15 AM
Flip's Avatar
It sounds like you have a clogged cat. Are you throwing any codes?
Old Dec 31, 2008 | 01:23 AM
kr1snarowsk1's Avatar
This happened to me too its definately a clogged cat. i took mine out and popped out the honeycombs so i'm runnnin straight pipes now and it runs great. If its shaking u might have a fuel filter/pump problem too try changing the spark plugs and fuel filter first then the pump if that doesnt help. most of ur problems should be solved with a new or stripped cat.
Prizmatik
Aug 12, 2013 01:48 PM
h4x0r
Jun 1, 2011 05:34 PM
kimi
Dec 1, 2009 08:36 AM
b0b0
Jun 28, 2009 12:35 PM
kimi
Jun 13, 2009 06:32 PM
