Got a problem with idle
Old May 31, 2008 | 10:58 AM
WayneGRA's Avatar
Default Got a problem with idle
I replaced the battery in my '99 A4 about a month ago, and I messed up the radio code so the radio is locked for now. After I replaced the battery I had to go to the dealer to get the computer reset to get the car running again. Well, since the radio was locked, I tried to input it again, so I had to unplug the battery again. Well, the same thing happened, and the car wont run because the computer needs to be reset.. Is there a way to reset the computer yourself, or do i have to go to the dealer and spend $200+ to get it reset? This problem sucks and I dont want to waste even more money after this happened the first time.
Old May 31, 2008 | 11:33 AM
CRAZYHAWK's Avatar
Default RE: Got a problem with idle
If your engine is Drive By Wire, do a throttle body alignment.
Old Jun 3, 2008 | 12:28 PM
tHe kNiGHt FaLL's Avatar
throttle valve adaptation... only way i know to do it successfully is w/ the scan tool
juha01
Apr 3, 2014 01:56 PM
justinclarke
Nov 25, 2010 04:03 PM
audiltr
Apr 24, 2008 08:41 PM
cbailey_369
Nov 19, 2007 04:00 PM
