Got problems
Old Oct 31, 2012 | 11:53 PM
Willy45015's Avatar
Default Got problems
Ok just picked up a 99 a4 Quattro 1.8t and none of the windows and door locks work but fuses are good is there a module that I can replace and also the transmission won't shift into over drive and the check engine light cone on an off for vehicle speed sensor and transmission range sensor but the vehicle speed works on cluster
Old Nov 16, 2012 | 02:26 PM
tommytunes's Avatar
For your power window and lock problem you could check the relays. You'll have have to take them out, look at the diagram and put power to them to see if they are working. Hope that helps!
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
