help appreciated for a3 issues!
Old Feb 20, 2015 | 11:08 PM
habs247's Avatar
Default help appreciated for a3 issues!
hi everyone, turning to the experts here. i've been a longtime lurker, but first time poster as i have no idea how to solve this issue with my car.
i have a 2008 A3 (2.0T, FWD, Canadian spec). About a month ago, I started getting an alert for a burnt out tail light (I checked, all lights are working fine, although tonight it I noticed one of the license plate light bulbs is out - could this trip that error)?
Anyway, my problems seem to be much bigger than that now. I turned on the car yesterday and it both my ABS and ESP lights came on (and stayed on).
Had the car scanned (also all the codes cleared - the abs and esp light came back right away), here are my results:
Code:
 Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: ---------    Mileage: 102170km-63485miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Not registered 0001
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 8P0 907 115 Q    HW: 8P0 907 115 Q
   Component: 2.0l R4/4V TFSI     0050
   Revision: AAH03---    Serial number: AUX7Z0H1FNK06P
   Coding: 0103010A1C070160
   Shop #: WSC 91520 999 53789
   VCID: 4084A2701331D0212E0-8015
2 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 015 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101111
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 102132 km
                    Time Indication: 0
                    Date: 2015.02.20
                    Time: 12:24:32
             Freeze Frame:
                    RPM: 1199 /min
                    Load: 31.4 %
                    Speed: 16.0 km/h
                    Temperature: 66.0*C
                    Temperature: 35.0*C
                    Absolute Pres.: 900.0 mbar
                    Voltage: 13.589 V
               U1017 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 102132 km
                    Time Indication: 0
                    Date: 2015.02.20
                    Time: 12:25:36
             Freeze Frame:
                    RPM: 857 /min
                    Load: 24.3 %
                    Speed: 0.0 km/h
                    Temperature: 72.0*C
                    Temperature: 33.0*C
                    Absolute Pres.: 890.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1404
   Revision: 04808020    Serial number: 00000908070432
   Coding: 0000020
   Shop #: WSC 04940 001 00001
   VCID: 19322F14D02BA1E989E-804C
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 102130 km
                    Time Indication: 0
                    Date: 2015.02.20
                    Time: 11:25:39
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60-F.lbl
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0053890
   Shop #: WSC 06314 000 00000
   VCID: 68D45AD05BC1C861C60-803D
2 Faults Found:
00668 - Supply Voltage Terminal 30
            008 - Implausible Signal - Intermittent
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 AH    HW: 8P0 820 043 AH
   Component: KlimavollautomatH19 0430
   Revision: 135148      Serial number: 8P0820043AH
   Shop #: WSC 00000 000 00000
   VCID: 72E038B86D1D32B1684-8027
No fault code found.
Address 09: Cent. Elect.        Labels: 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000008082786
   Coding: 098C0F81D01410004F1818001800000000384E175C110000000000000000
   Shop #: WSC 06314 000 08192
   VCID: 458AB3640C13F5091D6-8010
   Subsystem 1 - Part No: 8P1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
2 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 100454 km
                    Time Indication: 0
                    Date: 2015.02.07
                    Time: 17:21:00
             Freeze Frame:
                        ON
                    Voltage: 13.65 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 96087 km
                    Time Indication: 0
                    Date: 2014.12.07
                    Time: 13:56:00
             Freeze Frame:
                        OFF
                    Voltage: 12.00 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 M    HW: 8P0 959 655 M
   Component:    Airbag 9.41  H01 4220
   Revision: 91H01422    Serial number: 003CQ0003H8Q
   Coding: 0030605
   VCID: 4C9C86402F790441C28-8019
   Subsystem 1 - Serial number: 6332DRB406D28CAA1
   Subsystem 2 - Serial number: 6342DRB406D28CB0-
   Subsystem 3 - Serial number: 63528RB403949FDD3
   Subsystem 4 - Serial number: 63628RB40389E496Y
   Subsystem 5 - Serial number: 63747RB4036BABAA1
   Subsystem 6 - Serial number: 63847RB4036BAC03T
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0012142
   VCID: 4182A774183BD92921E-8014
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H02 0030
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
            012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 931 J    HW: 8P0 920 931 J
   Component: KOMBIINSTR. VDO H22 0660
   Revision: D0H22003    Serial number: 2241H003103096
   Coding: 0000378
   Shop #: WSC 47198 000 1048576
   VCID: 3A70D09875ED8AF1604-806F
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K082210C50
   Coding: ED807F061002022102
   VCID: 346CFEA057897C81BA8-8061
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 206
                    Mileage: 88283 km
                    Time Indication: 0
                    Date: 2014.07.22
                    Time: 19:01:13
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Revision: D0H22003    Serial number: AUX7Z0H1FNK06P
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0050
   Coding: 0001209
   VCID: 438EAD7C0227CB39332-8016
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.079 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 356AC3A45CF365898D6-8060
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 K
   Component:    KSG          H11 0080
   Coding: 1B8022A001382D09050FCC8F0477
   VCID: 448CAE600729CC010A8-8011
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802298692
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0001209
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 186 Q    HW: 8P0 035 186 Q
   Component: R Concert2+     H02 0270
   Revision: 00H02000    Serial number: AUZ1Z3H8959926
   Coding: 0330212
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 15
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0001176
   VCID: 4280A8781D3DC231384-8017
End-------------------------(Elapsed Time: 01:53)--------------------------
WOW. I've done so much reading online but I have no idea where to start. Is this a bad brake light switch? Bad battery? Even worse, a bad ABS module?
Would love your assistance guys!
AudiGirl92
B7 Models
10
Sep 18, 2013 10:06 AM
ttsroadster
Oct 17, 2012 01:22 PM
padog
Dec 17, 2008 09:08 AM
99 audi
Jan 2, 2008 09:48 AM
XSive
Apr 1, 2007 03:09 AM
