Help!! Brakes failed
Old Jul 21, 2006 | 04:57 PM
moleb's Avatar
Default Help!! Brakes failed
Hello all,
I nearly died tonight on the way home from work when the brake pedal went straight to the floor.
It feels like no fluid but I haven't lost any and I can't see any leaks. It's really scary this one because the brake pedal had no effect (even with a hard push). Any ideas?
Cheers,
Brian
Old Jul 21, 2006 | 05:01 PM
techbod's Avatar
Default RE: Help!! Brakes failed
air in system/ main vacuum pipe off the booster/ brakes been cut by a worker who doesn't like you J/K
Old Jul 21, 2006 | 06:13 PM
moleb's Avatar
Sabotage (could well be....). The thing is, there is no booster on this car (it's fed off the power steering rack). There is a large plastic 'bottle' under the front wing which is fed from the intake manifold.......do you know wht that is?
Old Jul 21, 2006 | 06:22 PM
techbod's Avatar
what car/ age / engine size
Old Jul 21, 2006 | 06:36 PM
moleb's Avatar
It's a '93 80 2.6 Avant. I've just tried the following (advise from another site):-
Turned steering full lock, pumped brakes 10 times. The warning light started to flash.....The advise given is that this is the PS pump or 'bomb'. Where is the bomb on a 2.6? Is it the large plastic bottle under the wheelarch?
ITSRTOY
May 23, 2011 04:40 PM
jwd2a
Jun 28, 2010 11:18 PM
Jenski
Aug 21, 2009 02:56 AM
BLK_A4
Dec 8, 2007 02:37 PM
Dj Spiel
Apr 16, 2006 06:52 AM
