help diagnostic code p1128
Old Jun 11, 2006 | 05:23 PM
00a4's Avatar
Default help diagnostic code p1128
I have a 2000 a4 1.8t and when i start the car after its been sitting it misfires. After about 30 seconds its idles out but i have noticed a loss of power and it misfires once in awhile when im driving. I pulled up the OBD code and it showed up a P1128 which is manufacturer controlled. I looked it up on the internet and it said it was " Long Term Fuel Trim Multiplicative, Bank 1 System Too Lean " I was wondering if anyone knew what the problem might be and if there is anything I can do to try and fix the problem, before I would have to take it to the dealer.
Old Jun 12, 2006 | 03:40 PM
NCAUDITECH's Avatar
Default RE: help diagnostic code p1128
from what i can find check your fuel pressure check your residual fuel pressure your system might be losing fuel pressure after you cut the car off. there should always be some pressure in the system
at idle pressure should be 50 psi
after you cut off engine wait 10 mins pressure should be above 36 psi if not you have a leak or faulty check valve in fuel tank
Old Jun 14, 2006 | 10:12 PM
SAudi's Avatar
i had the same code show up on my 2.8q when my dad put in 89 octane gas and didnt tell me. it also misfired. i simply drained the fuel and put in 100 octane znd added a bottle of fuel stableizer and cleared the code, let it run for about 30-60 minutes. everythings seems to be running fine after 4 months.
Old Jun 17, 2006 | 01:16 PM
CRAZYHAWK's Avatar
Could be a vacuum leak.
Old Jun 17, 2006 | 03:00 PM
techbod's Avatar
intake/exhaust leak, AIR ststem, hose leak
mandito219
Jul 17, 2009 08:53 PM
Stouffer
Jun 28, 2008 02:16 PM
yhkimdc
Oct 10, 2007 02:51 PM
co50
Feb 28, 2007 05:06 PM
00a4
Aug 23, 2006 07:17 PM
