Horrible Ignition Noise
Old Oct 29, 2007 | 01:48 AM
terminaltone's Avatar
Default Horrible Ignition Noise
I have an 02 A4 Quattro 5 Spd Mnl Tran w/ +100,000 miles.
When I turn on my car it makes a "scrapping" noise from under the hood. It doesnt make this noise when it is turned on for the first time in the day. About 8 hours since it was last on. Everytime after that it makes the loud noise. The noise lasts about 1 second and dies out. Any help? Thanks.
Old Oct 31, 2007 | 06:30 PM
tHe kNiGHt FaLL's Avatar
Default RE: Horrible Ignition Noise
the only ignition noise i kno of is a spark knock... no scraping... or scrapping...
but it is possible... that you have something affecting your base timing or cam timing... and when started this happens... and the ECU compensates for this... by adjusting timing...
i can't say for sure... cause its not a typical where people refer scrapping to ignition. it would be something i would have to hear and see for myself... and i think almost everyone is gonna say the same thing.
Old Nov 3, 2007 | 01:46 PM
McGovs2.7TB5's Avatar
I had a similar problem and it turned that my cam crank tensioner was not working properly added needed replaced that was at about 75000 miles. wasn't cheap. Like Knight Fall said without actually hearing the sound i could't say for sure but what you described seemed like what mine was doing. Along with the tensioner i had the mechanic replace my water pump and timing beltas preventative maintanceall said and done wasabout $2200.
qdoctr
Feb 4, 2014 06:16 PM
Bradley Scott
Feb 9, 2013 08:35 PM
mpoo83
Oct 14, 2011 07:36 AM
30vQuattro
Feb 12, 2008 02:29 PM
surfbumb321
Aug 27, 2006 02:12 AM
