i need help badly
Old Feb 14, 2006 | 03:03 AM
scooter420's Avatar
Default i need help badly
hi i have an audi a4 99 1.8t the problem is when i scan it i get a code for p0302 misfire in cylinder 2 now i checked everything i could think of the coil packs are good the computer is good there is power at the coil but no spark??oh yeah and the wiring is good i think??and there is not much more to the system?????please anybody any ideas?????
Old Feb 14, 2006 | 10:59 AM
techbod's Avatar
Default RE: i need help badly
p0302 = cylinder 2 - misfire detected possible faults are engine mechanical fault, wiring, ignition/fuel system, ECT/MAF sensor, ECM
Old Feb 14, 2006 | 01:55 PM
avanttripleloop's Avatar
easiest is to change the plug they can completely fail.second is to chek plug wire.could also be internal wire breakage.if you chek wires at night or in dark,a bad wire will show you its travelling spark.
Old Feb 15, 2006 | 03:13 AM
dankhound's Avatar
The ingintion output on your airbox is probably bad. They always fail on cylinder 2. TRy the coil and spark plug swaps to other cylinders to see if it follows. If the misfire remains on two replace the ignition output.
audi_n00b
Dec 19, 2009 12:35 AM
duderseb
May 21, 2009 06:10 PM
Banana
May 17, 2009 01:54 PM
webs
May 11, 2009 11:21 AM
JohnBoy1248
Sep 14, 2004 02:51 AM
