Inexpensive Fuel Gage Solution
Old May 1, 2007 | 12:00 PM
railrunner's Avatar
Default Inexpensive Fuel Gage Solution
I posted some months ago that I was having an issue with an innacurate fuel level sensor in my '03, A6, 4.2 (70K). The problem was that it was giving me a false reading on the remaining miles to empty as well as the needle gage on dash itself was innacurate. The result was an pain the **** running out of gas when it indicated I had over 100 miles left. The repair at a dealer was $750. I really didn't want to pay for something I could, with little effort, monitor by way of calculating avg. mpg and tank capacity.
Someone long ago in another post recommended BMW's fuel system cleaner. I want to say that after investing the $13, it was the best move I ever made. No promises that it will work every time or on every car, but I would recommend trying it before bending over for the repair. No issues since! Of course, there is a post here that tells you how to DIY, but it looks a bit tricky and messy. My needle will stick for a few minutes when I first fill up, but releases and does not stick again thrughout the tank's being emptied.
Hope it works for you as it did for me.
Old May 1, 2007 | 12:48 PM
techbod's Avatar
Default RE: Inexpensive Fuel Gage Solution
slick 50 fuel system cleaner its Teflon based
http://images.google.co.uk/images?hl...aner&gbv=2
Old May 1, 2007 | 12:49 PM
techbod's Avatar
mind you everything cost twice as much in the UK
Old May 1, 2007 | 02:29 PM
2k S4's Avatar
ORIGINAL: avant80@2.6
Well, your money is worth twice as much also!
You should start to use a cleaner every 6 months. It will help other things besides the fuel level sensor. If you need it replaced, find a local independent, I'm sure it's no where near $750.
IMHO, Redline SL1 & Amsoil PI are the BEST FSC out there!
Old May 1, 2007 | 08:36 PM
railrunner's Avatar
sincere thanks!
TTeriffic
Nov 4, 2010 01:00 PM
drewsph84
Dec 31, 2008 06:34 AM
railrunner
Jan 16, 2007 12:08 PM
larrye2001
Nov 26, 2005 08:05 PM
im timmy
Aug 3, 2005 10:10 PM
