Key Programming with Vag-Com?
Old Aug 10, 2007 | 11:58 PM
trevor51590's Avatar
Default Key Programming with Vag-Com?
I am once and for all trying to program my damn remote again so I follow the write up here:
http://audizine.com/forum/showthread.php?t=71439
Go to control module 35 for central locking. I go to adaptation 10 and go to channel 00 but it does not allow me to enter a new value. I then try to get to channel 01 and it says its not available. I look at 00 and appareantly there is no stored value? I am not allowed to enter in new values for some reason. Anybody have a clue?
Does it have something to do with logging in?
Old Aug 13, 2007 | 09:49 PM
Default RE: Key Programming with Vag-Com?
Nobody has a clue?
Old Aug 14, 2007 | 01:10 PM
CRAZYHAWK's Avatar
The following instructions are to reprogram your switchblade key fob.
1. Take a spare key and insert it into the ignition. Turn it one click forward.
2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
3. With your second key fob press the unlock button. The lights should flash.
4. Now lock the car with the key fob, and then unlock it.
5. Remove the key from the lock and the key from the ignition, and try it's function
Old Aug 16, 2007 | 04:43 PM
Thanks for the reply, but the reason I was going the VAG route was becasue this didnt work for me. BTW where in northern NJ are you?
Old Jul 30, 2011 | 09:10 AM
RLGarage's Avatar
Default A3 FOB Programming
This procedure did not work on my 08 A3.
I am going to try the VAG route next.
And BTW, the procedure in the owner's manual did not work either!
Old Jul 30, 2011 | 10:22 AM
RLGarage's Avatar
Default VAG COM 2008 A3 Fob programming
All
I have tried every method I can find to program a second fob on our A3. None, including the Ross Tech instructions work.
The key was allegedly programmed by the dealership, and will start the car and manually lock things, but the convenience settings for the remote will NOT get progammed for this key.
They do work with our original key fob.
Perhaps this has to do with the particular model of Audi, but if anyone has been successful doing this, please advise.
thanks.
StrongTyer
Mar 30, 2013 10:57 PM
Mhuntington
Sep 18, 2012 04:31 PM
nyaudia498
Jun 18, 2008 03:01 PM
ezlnh8u
Nov 13, 2007 03:07 PM
Joeski
Aug 28, 2006 02:06 PM
