Lots of smoke at idle
Old Mar 22, 2007 | 12:39 PM
lakesideaudi's Avatar
Default Lots of smoke at idle
I need some help. I have a 2002 a4 quattro 1.8t. I have been having some problems with lack of power until the turbo kicks in as well as the turbo not kicking in at all. I noticed that the hose that comes off the valve cover to crankcase and back to turbo was rotting away. I replaced the hose. I am also hearing a whining noise (dont know what from only under acceleration) I want to try the inexpensive things first. Everything I have read leads to the turbo but I was wondering if maybe a PCV valve or blocked line? The smoke is not a oil smoke or antifreeze, more like unburnt fuel. Any tips would be greatly appreciated.
Mike
Old Mar 27, 2007 | 03:57 AM
2k S4's Avatar
Default RE: Lots of smoke at idle
Do a boost leak test. Sounds like you have a boost leak, or a bad DV. Yes it can be the PVC system. Also pull the lower IC hose & see if there is oil in it.
Old Mar 27, 2007 | 11:40 AM
I took the turbo off and there is oil (1/2) quart in the incoming lines. Also there is some play in the fan inside the turbo. I am assuming it is bad. Any help where i can find a new one reasonabley priced? I found turbochargedpros for around $685.
Old Mar 27, 2007 | 02:16 PM
2k S4's Avatar
ORIGINAL: lakesideaudi
How much play? There should be a little. How does the exhaust side look? Is there oil in there? Oil on the compressor side is usually oil blow by so check the PVC system.
$685 for a new snail, it sounds good to me.
fengshui
B7 Models
9
Dec 14, 2010 05:33 PM
madman1234509
Apr 23, 2009 12:45 PM
Audi_Skydiver
Jun 5, 2007 09:34 PM
BlackOnBlackB6
Apr 20, 2007 08:51 PM
AudiCross
Nov 23, 2006 08:03 AM
