Memory Switch & Remote
Old Nov 14, 2007 | 12:36 PM
rvt1000's Avatar
Default Memory Switch & Remote
Car details 97 A6 Quattro
I bought this used and everything seems to work fine. The power mirrors/seats work in every direction but for some reason the memory switch does not. I have tried setting it according to the manual, but it does not store it. On the other hand the remote has the old owners info stored, so everytime I lock/unlock the car the mirrors move from my previous manual setting, to his setting. I have tried storing mycurrent setup of seat/mirrors into the remote but it will not store it. Do I have a bad memory switch ? Bad fuse somewhere that controls the switch ?
Thanks
Old Nov 14, 2007 | 07:26 PM
rvt1000's Avatar
Default RE: Memory Switch & Remote
Also forgot to mention I had the the batteries replaced on the remote and it still held the previous settings of the mirrors
Old Nov 14, 2007 | 08:03 PM
auditech79's Avatar
Your either not doing it correctly or the memory switch is bad. Also try looking at the sub harness inside the door which i have seen corrosion on the connectors before causing high resistance.
Old Nov 14, 2007 | 10:55 PM
rvt1000's Avatar
ORIGINAL: auditech79
Do I need to remove the door panel to get to the sub harness ?
ltooz_audis
May 27, 2014 12:13 PM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
Dynatnt1
Oct 8, 2006 05:59 PM
ruudje
Feb 25, 2005 12:48 PM
