Misfire Cylinders - Ign. Coil & Plugs Changed - Still won't start HELP
Old Mar 17, 2008 | 07:19 PM
Stockton B7's Avatar
Default Misfire Cylinders - Ign. Coil & Plugs Changed - Still won't start HELP
2005 Audi A4 2.0T Quattro:
Started engine (after parked for about 4 hours) car was shaking like it was about to stall, but didn't. Check engine light flashing, immediatly turned off engine. Generally checked hoses, oil, leaks, etc... started engine again, shaking was gone but the check engine light was solid. Drove home that night (65mph), noticed my MPG was barely reaching 20.0 - 22.0. Got home, parked... tried to move my car into the garage, STALLED on reverse, then would NOT START up again. Ran diagnosis check. Found these codes.
CODES: in this order
P0300 Random/Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0304 Cylinder 4 Misfire (Pending)
P0300 Random/Multiple Cylinder Misfire (Pending)
P0301 Cylinder 1 Misfire (Pending)
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction (Pending)
Did a little research through the Audi forums, found these common issues with the older models (B6). So I changed all 4 ignition coils and spark plugs, STILL WON'T START!
ANY IDEA WHAT IT COULD BE??? Before I take it to a mechanic and get taxed!
Old Mar 18, 2008 | 09:11 AM
CRAZYHAWK's Avatar
Default RE: Misfire Cylinders - Ign. Coil & Plugs Changed - Still won't start HELP
Reset the codes and see if they all return. Check
fuses.
Old Mar 18, 2008 | 10:42 AM
Codes did not return and fuses are all good... still wouldnt start. I tried it yesterday. I'm having towed today. I'll keep posting the status in case this happens to anyone else. Thanks for the reply though.
Old Mar 19, 2008 | 09:07 PM
geoff's Avatar
an ignition coil proabably shorted out and caused the ecm safety fuse to blow. it's located in the ecm box in the left rear of the engine bay. it's one of the 15 amp fuses if i remember right. this is a common problem with 2.0 liters. be sure to find the shorted coil before replacing the fuse otherwise you may over heat the ingine wiring harness. i'm an audi tech so if you have any more questions let me know
Old Mar 20, 2008 | 10:45 AM
THANKS GEOFF! I'll try that out today and see if that works. The only thing is... I already changed all 4 ignition coils for peace of mind, but I didn't check to see which one was shorted... I'll replace the fuse anyways. THANKS AGAIN!
Old Mar 20, 2008 | 11:16 PM
PRican1.8T's Avatar
what about on a 2000 A4 1.8Tfwd? it's the same problem except i only have p0301, 302, 303, and 304 (misfiring in cylinders 1-4) and i already replaced everything but still shakes on cold start and then calms down when it's warmed up.
Old Jun 19, 2008 | 04:15 PM
pengkha's Avatar
you need to replace the ignition control module. i had the same exact issue with my car. audi wanted like $600 for it but you can find it here for a great price
http://www.ecstuning.com/stage/edpd/...ategory=Engine
try that if you haven't yet it is amazing how that little control unit causes a huge misfire like that.
Note: mine is a 99 audi 1.8t though. the factory one is normally a bosch unit and it is located under the plasic cover on top of the air filter box. i replaced it with the huco unit and it worked fine. again it is the ignition module.
please check to see if it applies to your car being it is a 2000. if not then hey, at least it was some advise, and from experience that saved me a LOT of money from the dealer. if you have any questions feel free to email me at pengkha@yahoo.com.
Old Jun 21, 2008 | 02:09 AM
tonelee1316's Avatar
ORIGINAL: pengkha
it doesnt apply to him he'spre-facelift
Old Oct 16, 2013 | 02:31 AM
Stephen Todd Tackett's Avatar
Default 05 Audi Misfire
I have A4 05 with the same exact issue. I have tried all the recommended solutions to no avail. Did you ever find out what the problem was?
Thanks,
Stephen
Old Mar 17, 2016 | 01:21 PM
DIESELDADDY8's Avatar
Default 2005 audi a4 1.8t need help icm located
I try to find icm located help me out thank
g1nger
Mar 9, 2011 09:30 AM
bigbluebudda
Dec 17, 2010 03:13 AM
MoD3lag
May 22, 2010 12:50 AM
lowell513mx
May 3, 2008 01:22 AM
goc305
Apr 27, 2007 07:41 PM
