Is My Motor Blown??!!
Old Jan 30, 2006 | 12:36 AM
Budcan's Avatar
Default Is My Motor Blown??!!
OK, I'm driving from Charleston to Charlotte and the oil light comes on after having run a couple hours. I live in Florida, so I'm far from home and pretty much no where. I pull over and check the oil. Basically OK, maybe a little low as I'm coming up on an oil change. Get off the highway and add alittle to get it to the top of the hashes but the light is still on. But oil is ok, so I go. Its running fine. Sounds normal until it starts loosing power. I pull over and shut it off. Check oil-fine. Try to start it and nada. No turn over.
Five hours later it is dropped off at Audi Charlotte and I'm friggin stuck. The car is a 2002 A4 Avant that the sticker in the Waranty book has a date of 06/02 on the opening page. I assume that is the waranty start date? I don't understand all the other numbers other than the vin. I leased it 06/03 for 39 months. It already had 7400 miles on it having been a loaner. Currently has 45000 miles on it.
Any guesses what I'm going to hear in the morning? I went through past posts on the subject and assume it was a sludge/oil pump issue and wish I had this knowledge prior to tonight. Oils been changed with synthetic well below the 10000 and recall work has always been done. Anyone know where I stand here???
TIA!
Old Jan 30, 2006 | 12:49 AM
a4BRZLowrider's Avatar
Default RE: Is My Motor Blown??!!
same thing happened to a friend,,lights on ...no oil....stopped at next gas station..filled ...no start...i think the motor blew...dont know yet
Old Jan 30, 2006 | 06:36 PM
Budcan's Avatar
This is rich. It is blown and am being told that because there was an aftermarket(wix) filter on the car the waranty is void. Told me to pony up $14000! HAHAHAHAHAHAHAAA...
Old Jan 31, 2006 | 12:55 AM
mastvadz71's Avatar
Member
DON'T WORRY IT IS UNDER WARANTY.EVERY OTHER 2002-2003 A4 1,8 HAS THAT PROBLEM.THEY MUST REPLACE THE ENGINE WITH NO CHARGE WHATSOEVER,WHATEVER THEY TOLD YOU IS BIG B.S. CALL AUDI OF NORTH AMERICA AND GO MAD.TRUST ME I WORK FOR AUDI AND I HAVE SEEN THIS MOTHER ******* TO PULL SO MUCH BULSHIT .DON'T LET THEM **** YOU UP
Old Jan 31, 2006 | 01:00 AM
luvin_the_rings's Avatar
the caps lock is a good 7/16' from your hand... press it...
Old Feb 3, 2006 | 01:27 AM
rbrtech's Avatar
All VW Passats and Audi A4 1.8t 98 and newer are covered under a warranty against sludge build which causes the oil light to come on 95% of the time. The warranty is 8 years unlimited miles. The catch is you need all of the service records since you owned the car. I have had two of my customers covered under this and one even blew out rod bearings.
Old Mar 13, 2006 | 05:23 AM
cdmx's Avatar
were you experiencing any kind of noises?
Old Mar 14, 2006 | 07:42 AM
pznuttz's Avatar
hey there,
does this mean the 96'and 97's are less prone to this very serious condition?
Old Mar 16, 2006 | 02:16 PM
baal2005's Avatar
Is it true that you have to come up with all the service records even before you owned the vehicle? It seems pretty hard to obtain especially if they went to independent servicers (i.e. Jiffy Lube etc.). Is there an easy way to find this information?
capuanofire
Apr 12, 2011 04:33 PM
thareals4
Jan 10, 2011 08:45 PM
myeeri15
Mar 22, 2009 07:59 PM
PlatinumX987
Sep 4, 2007 08:27 PM
teckm3
Mar 15, 2007 06:37 PM
