Is it my starter??
Old Jun 15, 2006 | 04:58 AM
Dr!ven's Avatar
Default Is it my starter??
So i tried to start up my mom's car tonight and it doesn't start. It doesn't even crank, all you hear is real fast click,click,click,click......... I think it is the starter unless anyone else have any other ideas.
Old Jun 15, 2006 | 06:08 AM
wonka's Avatar
Default RE: Is it my starter??
Car starting problems can usually be traced either on the battery, starter, key or the engine itself. Try checking out any of this component to solve your problem.
Old Jun 15, 2006 | 02:53 PM
beefski's Avatar
Sounds like a weak battery. Try a jump.
Old Jun 17, 2006 | 12:00 AM
AWDaholic's Avatar
Senior Administrator
That clicking sound is teh solenoid attempting to engage teh starter motor. If a jump doesn't do it, it's teh solenoid, but, since you generally can't but a solenoid without the rest of teh starter, you'll (she'll?) be replacing teh starter. Easy check is to find teh starter (it'll be inderneath teh motor, close to the block, hard against the flywheel/bellhousing assembly) and short across teh connections. Assuming teh battery's good, if the solenoid's gone it won't bump. A thought occurs... How corroded are teh termiinals on Mom's battery? If they need cleaning, clean them (Coca-Cola works good for this, for some reason). Then charge teh battery and try and start it, again.
ummm... what kind of car is it, BTW?
Old Jun 21, 2006 | 05:50 PM
audilifedude's Avatar
i would also guess the battery, by the clicking it starter is not getting enough juice to get that car started. I would also recommend jumping the car and then going from there.
Pat W
Oct 20, 2025 04:16 AM
Dallas09
Sep 27, 2010 10:48 PM
im so audi5000
May 2, 2009 11:23 PM
Dr!ven
Jun 16, 2006 04:22 PM
auDi1.8TQ
Feb 22, 2006 03:07 AM
