no blower fan or temp for outside
I have a 2000 audi TT Coupe Quatro 1.8 i pulled the stock cassette stereo out of it and i dont know wat happened cause my heat worked fine before i did this know i dont have nothing like theres no juice to it at all just blank is there anothe fuse panel i dont know about i checked all the ones on the side of driverside n showed up good any help would be appreciated thank you
Is the climate control unit stationed right above or below the radio? If it is, pull the radio back out and check the connections to the back of the climate control.. Removing the radio may have disturbed the connection on the back of it.
thank you very much i will check it tonight when i get home
