no heat
Old Nov 2, 2007 | 12:42 AM
mrelms's Avatar
Default no heat
ok every one seems to think when there is no heat it is a clogged heater core, that my be possible, but has anyone come across a malfuntioning blend door due to a broken plastic gear. prior to pulling the dash apart what would be the best way to diagnose this problem.
Old Nov 2, 2007 | 01:44 PM
tHe kNiGHt FaLL's Avatar
Default RE: no heat
its gotta be done w/ a scan tool... measure values from the scan tool can tell wha position each door motor is in...
or you could disconnect the lines going in and out the heater core and blow compressed air in it.
pinch off the coolant lines tho.
Old Nov 2, 2007 | 10:38 PM
mrelms's Avatar
Default RE: no heat
thanks i didn't know a scan could tell what position the doors are in
cu52
Oct 28, 2009 11:50 AM
lorencew
Feb 9, 2009 01:15 AM
Excape
Sep 19, 2008 03:07 AM
jimmyt853
Feb 21, 2007 05:50 PM
shelby69
Feb 15, 2007 09:35 PM
