O2 sensor nightmare! help
Old Jan 28, 2008 | 12:53 AM
pumpercloggs's Avatar
Banned
Default O2 sensor nightmare! help
Just ordered new downpipes cat and muffler for my 97 a4 2.8. I wanted to re-use my 02 sensors in the new piping, unfortunately, the rear o2 sensors would not come out while the pipes where attached to the car, so I cut the wires of the rear o2 sensors, and later removed them in a vice. Problem now, I thought there were only 3 wiresper o2 sensor, but the rear o2 sensors have 4, 1 black 1 grey and 2 white. I need some help in order to re-connect the wires back together, does anyone have a link or diagram explaining how an o2 sensor works and is wired into this car? Also, if anyone knows where the rear o2 sensors plug in up front, I could trace the wires back to the plug and try to make some sense of it there, but I dont know which plug is for the rear o2, THANKS IN ADVANCE,
Old Jan 28, 2008 | 01:21 AM
auditech79's Avatar
Default RE: O2 sensor nightmare! help
All the O2 sensor connectors are on the firewall right there on each side of the engine. Two on each side.
Don't bother re-wiring them with connectors, you will end up getting fault codes from resistance in the circuit.
Just get both the sensors from www.ecstuning.com, they are a lot cheaper than the dealer.
Old Jan 28, 2008 | 11:23 PM
dankhound's Avatar
Your talking 0-1v on the signal wires. Not really room to spare on a bad connection.
pinay808
Jun 21, 2013 05:09 AM
2alpha56
Oct 23, 2009 01:38 AM
tdotA3mike
Oct 29, 2008 12:32 AM
D Bo
Sep 23, 2007 11:50 AM
anna
Dec 28, 2006 12:10 PM
