Oil Changing Q's
Old Feb 6, 2008 | 01:07 AM
JOnJOn's Avatar
Default Oil Changing Q's
How's it going, I just purchased a 2003 A4 and the dealer made it sound like changing the oil on this 1.8t is difficult. Does this require a special tool or are the parts (ie. Filter...) hard to acquire? Thanks...
Old Feb 6, 2008 | 01:15 AM
auditech79's Avatar
Default RE: Oil Changing Q's
No special tools required.
19mm wrench to take off the drain plug, and a filter wrench to loosen the filter.
It can be a little dirty though because the filter is mounted on the side of the engine over the subframe so oil tends to run all over the frame. What i usually do is get a couple of bags and wrap it around the filter to catch the oil from the filter. (Do this from above the car moving the coolant resivior aside)
Old Feb 6, 2008 | 02:06 AM
JOnJOn's Avatar
Cool, that is what I thought by the quick look that I got at the dealership. Where is a good place to get the "Larger OEM Oil Filters"? Thank you for the quick reply...
Old Feb 6, 2008 | 02:14 AM
JOnJOn's Avatar
Got a couple good links from a prior post... Thanks
Old Feb 6, 2008 | 02:17 AM
JOnJOn's Avatar
How much oil is required for a oil/filter change? Thanks...
Old Feb 6, 2008 | 11:41 PM
dankhound's Avatar
5 quarts will be plenty. It should use slightly over 4.
madridlover
Jul 2, 2012 01:44 PM
raudi28
Aug 17, 2011 02:13 AM
playboy00786
Jul 3, 2009 11:34 PM
Booney1.8
Feb 7, 2008 01:27 PM
ZedEx
Dec 21, 2005 03:39 AM
