pin point why battery going dead when off,good battery tried parasitic draw,checked fuses,
Old Dec 3, 2007 | 09:10 PM
salinas's Avatar
Default pin point why battery going dead when off,good battery tried parasitic draw,checked fuses,
well tried parasitic draw checked fuses went through process, still no luck still havent tried
new ignition switch, any other trouble shooting things i can try, working on getting diagnostic check , waiting for friend to help , any other ideas of why when audi is shut off it is drawing battery dead............? have to figure out if ignition switch is bad before i pick one up,any info is
greatly appreciated, thanks a bunch salinas...................!!!!!!!!!!!!!!!!!!!
Old Dec 3, 2007 | 10:52 PM
dankhound's Avatar
Default RE: pin point why battery going dead when off,good battery tried parasitic draw,checked fuses,
If you have a parasitic draw of less than 50milli amps. Thats .050 amps. I would say you have a bad battery. Its not unheard of for a brand new battery to not want to hold a charge. If thats the case i would recomend a new battery eventhou it may pass all battery tests.
Old Dec 7, 2007 | 04:42 PM
njjack2's Avatar
Check the ground...where it mounts to the frame. If it is loose it could cause a draw.
Old Dec 9, 2007 | 08:11 PM
TheAudiTech's Avatar
WHAT? There is no way a loose connection on the ground could cause a draw. How could a connection that has more resistance than it should cause an increase in a VD?
Old Dec 9, 2007 | 08:35 PM
auditech79's Avatar
It would really help a freaking lot if you posted which car you have, the year, and engine.
If you have navigation un-plug it and see if the draw goes away, common problem.
Old Dec 11, 2007 | 08:09 PM
salinas's Avatar
if you looked at my introduction you would know what make and model i have,.........................
travis
vance_b
Jun 4, 2014 08:40 PM
Liebetrau88
Apr 13, 2010 12:21 AM
pznuttz
Jun 30, 2008 11:52 PM
