Please help with multiple error codes!
Old Mar 18, 2016 | 12:12 PM
jerry161's Avatar
Default Please help with multiple error codes!
I have a 2007 Audi A4 2.0t. It has 140,000 miles on it. Recently the check engine light came on and displayed the codes below. I'm not very knowledgable on Audi vehicles and want to figure out where to start here.
If you have knowledge of what these codes may signify please let me know...
05491 left engine mount solenoid. N144 open circuit. P1573 no signal/ no communication
01090 evap emission control system small leak P0442 upper limit reached.
12555 Low pressure fuel regulation. Pressure outside specs. P310b no signal no communication intermittent.
01110 Evap system very small leak detected. P0456 upper limit reached.
Please help!
Old Mar 18, 2016 | 04:16 PM
dave944's Avatar
05491 is a broken engine mount that has separate. The is not really a critical thing but you need to replace it soon.
01090 Could just be a defective Purge Valve
12555 check the vacuum hose to the fuel pressure regulator. Check for any cracks in the rubber or plastic portion of the line.
01110 could be related to the Purge Valve.
rbv24
Dec 30, 2011 07:50 PM
dandefronzo@gmail.com
Oct 22, 2010 11:47 AM
ilovelagar
Oct 22, 2008 12:37 PM
matt1colorado
Aug 21, 2006 11:12 PM
