Power Steering noise (buzzing when cold)
Old Dec 26, 2013 | 12:37 PM
northgeorgia's Avatar
Default Power Steering noise (buzzing when cold)
I keep getting this power steering noise problem when the temperature gets around 30 degrees. It buzzes, and when I reach the farthest left or right turn of the steering wheel it begins to chatters.
I've check the power steering fluid and it is topped off and clean - it's been that way forever. The only thing I can think of is that it may have some water or something in the lines and then it either freezes or thickens to the point where it restricts the flow of fluid.
At least until it gets warm again. I don't know. Anyone ever hear about this?
Old Dec 26, 2013 | 12:53 PM
Michigan 01 S4's Avatar
I have never heard anything similar to that, however. I would consider having your steering rack checked though. Maybe a complete flush of your Power steering fluid as well.
Old Dec 26, 2013 | 01:00 PM
You may have a idea with the flush - it is an older A6 (2001 A6 Quattro with 107K). Thanks a million for the quick reply.
Old Dec 26, 2013 | 01:25 PM
M5S5's Avatar
Tech Certified
The low pressure hose right off the pump will suck air & make all sorts of noise. replace hose & both clamps If you look at the fluid after turning the wheel it will probably have bubbles.
Old Dec 27, 2013 | 09:05 AM
This is also a good idea, my friend has a b5a6 also. Working on his inspired me to buy my s4.
gtstill
Feb 13, 2014 05:16 PM
shuggy81
Aug 13, 2012 10:48 AM
arman123
Apr 6, 2009 02:56 PM
justinclarke
Sep 19, 2008 03:31 PM
jshodgson
Oct 6, 2006 04:17 AM
