Power Steering Fluid, check when hot or cold?
Old Sep 19, 2008 | 09:07 AM
justinclarke's Avatar
Default Power Steering Fluid, check when hot or cold?
This may sound like a stupid question but do you check the power steering fluid level when the engine is hot, or when it's cold?
Or shouldn't it make any difference?
Cheers.
Old Sep 19, 2008 | 09:10 AM
compmanben's Avatar
I usually check it when the car is cold.
Old Sep 19, 2008 | 09:16 AM
airguard350's Avatar
Tech Guru
Same here
Old Sep 19, 2008 | 09:19 AM
Cool nice one. It's just I checked when cold, and it was low-ish, so I topped it up, and now the powersteering is acting up a bit. But maybe it's just a problem with the pump. Thanks.
I thought I may have over filled it by filling it up from cold. But that's not the case then.
Old Sep 19, 2008 | 03:31 PM
Tech Guru
How many miles are on the car? Is it a creaking sound? If it is you have a bad outer tie rod end. I should be getting my car back from the shop today for that.
foulkrj
Oct 18, 2008 11:55 AM
duburban
Jan 3, 2008 07:17 PM
thrax982
Mar 31, 2005 10:15 PM
