the real fault codes free
Old Mar 5, 2006 | 12:29 AM
  #21
kakarot's Avatar
Default RE: the real fault codes free
okey, I make this post as a mark that I have actually started it. I will download and then type.
I do not know how much each post can hold so I will find out soon.
Old Mar 5, 2006 | 01:17 PM
  #22
kakarot's Avatar
page one done, took me like 30min, thats long, need better quality pics
17937 P1529 Camshaft position (CMP) control. short to positive
- Wiring short to positive, CMP actuator
17938 P1530 Camshaft position (CMP) control. short to earth
- Wiring short to earth, CMP actuator
17939 P1531 Camshaft position (CMP) control. open circuit
17940 P1532Idle control - lean running speed below specification
- Throtle control unit
17941 P1533 Camshaft position (CMP) actuator, bank 2 circuit malfunction
- Wiring, CMP actuator
17942 P1534 Camshaft position (CMP) actuator, bank 2 short to positive
17943 P1535 Camshaft position (CMP) actuator, bank 2 snort to earth
- Winnq short to earth. CMP actuator
17944 P1536 Camshaft position (CMP) actuator, bank 2 open circuit
17945 P1537 Fuel shut-off solenoid - malfunction
- Fuel shut-off solenoid (leaking/sticking)
17946 P1538 Fuel pump relay - open circuit/short to earth
- Wiring open circuit short to earth, fuel shut-off solenoid
17947 P1539 Cutch pedal position(CPP) switchWiring,
- CPP switch range/performance problem
17948 P1540 Vehicle speed signal - high input
- Excessive vehicle speed, instrument panel defective
17949 P1541 Fuel pump relay - open circuit
- Wiring open circuit, fuel pump relay
17950 P1542 Throttle motor position sensor 1 - range/performance problem
- Throttle valve requires cleaning wiring, throttle motor position sensor
17951 P1543 Throttle motor position sensor 1
- low input Wiring short to earth, throttle motor position sensor
17952 P1544 Throttle motor position sensor 1- high input
- Wiring short to positive, throttle motor position sensor
17953 P1545 Throttle valve control - malfunction
- Throttle valve tight/sticking, wiring, throttle control unit
17954 P1546 Turbocgharger (TC) wastegate regulating valve - short to positive
- Wiring short to positive, TC wastegate regulator valve
17955 P1547 Turbocgharger (TC) wastegate regulating valve - short to earth
- Wiring short to earth, TC wastegate regulator valve
17956 P1548 Turbocgharger (TC) wastegate regulating valve - open circuit
- Wiring open circuit, TC wastegate regulator valve
17957 P1549 Turbocgharger (TC) wastegate regulating valve - open circuit/short to earth
- Wiring open circuit/short to earth, TC wastegate regulator valve
17958 P1550 Turbocgharger (TC) pressure - control difference
- Intake/exhaust leak, hoses interchanged/not connected, MAP
sensor, TC wastegate regulating valve, turbocharger (TC)
wastegate actuator, TC
Shaunw90
Jun 26, 2011 06:07 PM
PandaXpress
Jul 25, 2009 10:47 AM
carlv
Apr 23, 2008 04:22 AM
02DolphinA4
Jan 23, 2007 07:23 PM
mitao2000
Aug 30, 2006 11:53 AM
