Rumble/Vibration from rear wheel(s) when turning. Wheel Bearing?
Old Dec 31, 2013 | 01:33 PM
Kyle_vdk's Avatar
Default Rumble/Vibration from rear wheel(s) when turning. Wheel Bearing?
Hey guys,
I have an Audi A4 B5 (2000) 1.8t quattro 5spd.
I've read a bit about this problem and It seems to be my rear wheel bearing(s). When I am going straight or turning left I can hear this rumbling from the back wheel (it sounds like it is coming from the back right wheel) but if I turn right (even the SLIGHTEST right turn, as in the direction of my car barely alters) the noise goes away. Is this my rear wheel bearing?
I haven't had much experience working on cars but I think I know what I am doing, is it a good idea to do this job myself (but get the bearing pressed at a shop). Also what happens if I don't replace the bearing any time soon? (the noise has been getting worse as of late)
The bearings appear to be 50 bucks, how much does a shop usually charge to press the bearings in?
Thanks
Old Jan 11, 2014 | 10:25 PM
ImTheDevil's Avatar
Most likely it's your right rear wheel bearing. You'd have to call around to get rates for the change. Keep in mind you'll need an alignment afterward unless the shop you find has a Hub Shark and can press it with the spindle still on the car.
Mr. Phil
Mar 28, 2010 12:46 AM
Andrew149
Oct 6, 2009 04:11 PM
TheBat
Aug 12, 2009 04:05 PM
Armenian
Jul 7, 2007 08:33 PM
MadMaxGT
Apr 30, 2007 08:41 AM
