secondary air pump ??
Old Jul 21, 2008 | 05:05 PM
BOOSTME's Avatar
Default secondary air pump ??
so my SAP is shot and it sounds like a hairier jet on cold start ups and im throwin a P1128 code
BOOSTME's Avatar
Default RE: secondary air pump ??
could this also cause my turbo to loose pressure (alot) and yes i already checked for obvious vacuum leaks
2000 A4 1.8T
Old Jul 22, 2008 | 03:36 PM
Sethg10's Avatar
No, it won't cause your car to lose boost pressure. You should check the secondary air pump and make sure the casing is split instead of a hose that came loose.
Old Jul 24, 2008 | 07:29 PM
BOOSTME's Avatar
i havent got time to check for air leaks by the air pump yet. but this morning when i started the car it did the whole whining and stuttering thing but this time the CEL would flash meaning the cat is being damaged but after the whining died down and the car stopped stuttering the CEL went back to being solid. Could this still be caused by just an air leak?
Old Jul 24, 2008 | 11:04 PM
tHe kNiGHt FaLL's Avatar
P1128 off the top of my head... i think is a Coolant Temp High Input Code...
and on 2.7's when the mileage gets around 70k the secondary air does get louder... not making it faulty.
i dunno the year / model you have...
Old Jul 25, 2008 | 08:55 AM
CRAZYHAWK's Avatar
17536 P1128 Long Term Fuel Trim mult., System too Lean
Chech for vacuum leaks.
boostedboot
Dec 13, 2011 11:10 PM
jeeps5
Sep 22, 2011 06:01 PM
Reiem125
Mar 15, 2009 02:31 AM
moeron7
Nov 29, 2007 06:03 PM
