Spraying coolant over top of engine (B5 S4)
Old Nov 22, 2011 | 12:55 AM
rdoherty's Avatar
Default Spraying coolant over top of engine (B5 S4)
Hi everyone, newbie here. My S4 (2001, MTM chip, short throw) is spraying coolant somehow over the top of the engine near the intake (see pic below).
Coolant level is ok (low, but not below the low line), no error codes (took it to a good mechanic who is very familiar with Audis), coolant system holds pressure (I watched the mechanic pressurize the coolant reservoir to 2x normal) and it's not dripping any coolant when off.
It seems to have sprayed a lot more during a track day over the weekend. I saw a few white specs a month or so ago and didn't think anything of it until now.
Any ideas? My mechanic says there isn't anything around this area that could really spray anything. The coolant reservoir is clean, so I'm pretty sure it's not coming from there.
Could it only be spraying when the engine is warmed up and being driven hard? I'm out of ideas and new to Audis so I'm not sure where to look for more information (I've Googled this issue for the past hour).
Thanks in advance for your help!
Old Nov 22, 2011 | 04:33 PM
rdoherty's Avatar
For future people that find this forum post: there is a 2nd water pump under the intake that often fails. Check there!
Old Nov 22, 2011 | 10:28 PM
ImTheDevil's Avatar
Exactly what I was going to mention. The afterrun pump fails a lot on the 2.7T. Relocate it to the secondary firewall or ditch it altogether.
I'm surprised your mechanic didn't know anything about it...
Old Nov 22, 2011 | 11:50 PM
rdoherty's Avatar
I agree, I took the car to a mechanic literally next door and without them looking at it they mentioned the second pump. Guess I won't be going back.
Old Nov 26, 2011 | 03:13 AM
rdoherty's Avatar
Default And bust
Bust, wasn't the second water pump. Mechanic thinks it's the coolant cap, but I'm not convinced, there is coolant being sprayed in areas where the coolant would have to do a complete 180 if it came from the cap. Sigh.
Old Nov 26, 2011 | 02:05 PM
02A6Beau's Avatar
I keep looking a the picture. head scratching. thinking about it. I can't really come up with anything reasonable for how coolant can get sprayed in the places I see it in the pictures.
a coolant reservoir cap is pretty cheap. without any better suggestions, can't hurt to give it a shot
schwanz583
Apr 6, 2015 07:26 PM
KG89
Jun 28, 2011 09:52 PM
audi4power
Mar 10, 2006 01:09 AM
///A4
Jan 27, 2006 12:48 PM
