tep light on dash coming on????
Boiling coolant is never a good sign. Your coolant content in relation to the water content probably is too low. I would drain and refill with 50/50 coolant to water ratio.
I have a 96 also and at one time my temperature gauge was reading low. It ended up being the connector on the temperature sensor not making a good contact. I pulled it off sprayed it with contact cleaner and the gauge returned reading a normal temp. In your case the gauge may be lying to you and the temp light is real. Another time I was slowly losingfluid and it ended up being the connection from the over flow line into the radiator reservoir. the reservoir was cracked at the connection.
dkay
May 28, 2007 07:16 PM
