Time for new Timing Belt?
Old Feb 10, 2006 | 01:33 PM
tuckerm's Avatar
Default Time for new Timing Belt?
Hi am am new around here and to Audi!
Just bought a new old 1994 100 CS with 125K. Car is in great shape. Trans fluid is dirty, and few other small maintenace issues. My mechanic Goltz motors, could not figure out if timing belt had been done. We do not know the original owner. Anyway to figure this out???
Thanks, Matt
Old Feb 12, 2006 | 01:40 PM
dankhound's Avatar
Default RE: Time for new Timing Belt?
You may be able to track down previous owners thru the department of motor vehicles. If they looked at the belt and couldnt tell if it was new, your best bet would probably be to replace it.
Old Feb 13, 2006 | 12:29 AM
Jestnomen's Avatar
6th Gear
Have the mechanic flip the belt over to look for wear and cracking. If any is present then get the belt changed. Most likely it hasn't been changed anyway.
Old Feb 15, 2006 | 01:04 PM
tuckerm's Avatar
Thanx!!
Yea mechanic said once he gets it open he will be able to tell. With 126K I guess it could be on its 2nd.
Is the auto trans on these cars bumpy??
Old Feb 21, 2006 | 04:36 PM
tuckerm's Avatar
So....
I had the work done, to a note of $1400, hard to swallow for a car that I paid $3600 for.
1) All maintenace except for a repair of the passengerside door latch which my mechanic was able
to soak and get working again 150
2) Lube, oil and filter 30
3) Brake fluid changed 110
4) Service trans,Trans Fluid changed 200
5) Timing Belt changed, when they got in there they had to replace tension assembley and Idler pulley and roller 650
6) Replace and repair crank pulley and seal (small oil leakage) 55.
I guess I got a great car for $5000, outstanding condition. I hope $$$$$ spending this is not a pattern.
Are these prices reasonalbe?
Old Mar 13, 2006 | 05:19 AM
cdmx's Avatar
wow i feel bad
I just got a 99 audi a4 1.8t Quattro 97k miles for only 4k
ckappler
Sep 7, 2009 04:10 PM
FortyCal
Oct 24, 2007 07:32 PM
twenty8red
May 8, 2007 08:55 PM
cary12
Nov 3, 2006 02:09 AM
socalaudi
Mar 13, 2006 02:39 AM
