tiptronic will not shift
Old Sep 13, 2006 | 02:23 AM
KS's Avatar
KS
Default tiptronic will not shift
Does anyone know what causes the tiptronic to not shift? I have a 99 a4 wagon that when you put the shifter over and shift up or down nothing happens.when the car is in drive it shifts normal. any help would be greatly appreciated.
Old Sep 13, 2006 | 06:31 PM
a6xlr8s's Avatar
Default RE: tiptronic will not shift
There is a computer controll called an ecm that tells the trans what to do. It could also lock you into one gear when in auto mode. It would report codes when hooked up to a cpu if it is not working properly. It is directly responsible for the tiptronic system.
Old Sep 15, 2006 | 02:20 PM
evl6096's Avatar
your fuse might need changed
i had a battery problem one day and in turn my tiptronic stopped working and turned out it was only the fuse
Old Sep 17, 2006 | 06:28 PM
KS's Avatar
KS
i cant find manuel for car. do you happen to know which fuse it is. also if it is fuse box on drivers side door. or is there another fuse box? this is first audi i have owned mostly had subaru's . any help would be great thanks
Old Sep 17, 2006 | 06:36 PM
techbod's Avatar
#15 and #31 in the side you said
01 Avant
Jan 26, 2013 09:16 AM
Jebs451
B7 Models
Sep 22, 2012 06:22 PM
1998audiA6_Q
Sep 23, 2011 01:48 PM
Milez
Mar 28, 2011 09:47 PM
RLGarage
Nov 22, 2006 12:20 AM
