unplugged battery
Old Oct 28, 2008 | 02:05 PM
gabec007's Avatar
Default unplugged battery
I have an 01 alloroad. Unplugged the battery and car won't start. What do I need to do to get it running again?
Old Oct 28, 2008 | 03:10 PM
zippy_gg's Avatar
Plug the battery back in! LOL
Seriously, is your battery charged? The immobilizer may need to be reset... Your radio code will have to be re-entered. The throttle position will need to be reset.
Old Oct 28, 2008 | 04:35 PM
gabec007's Avatar
So I don't need to have a scan tool to reset it? And how do you reset the immobilizer and throttle position?
Old Oct 28, 2008 | 06:13 PM
CRAZYHAWK's Avatar
The immobilizer resets when you insert the key.
After connecting the battery, turn the key
part-way, don't crank. You should hear the throttle
moving for 2 minutes.
You should be ready to go.
Old Oct 28, 2008 | 09:39 PM
Darkprodo's Avatar
you can't reset the immobilizer. but then again disconnecting the battery has no effect on it anyways
Old Nov 8, 2008 | 11:00 AM
ungawa's Avatar
So I'm guess that the best bet it to keep some aux power suppy powering the car while changing a battery? I'm doing mine today and I'm reading all sorts of horror stories. I also happen to own an 01 allroad.
Edit update: FYI... I just used some jumper cables running to my John Deere (off) and swapped the batteries out quickly and had no problems.
samcrored
Jan 26, 2014 07:33 PM
pmis91
Sep 18, 2011 01:38 AM
trevor51590
B7 Models
Aug 2, 2010 12:10 PM
fireman9585
Aug 31, 2008 11:07 AM
LampyB
Apr 4, 2007 06:25 PM
