Wastegate Actuator Assembly
Old Mar 12, 2007 | 12:33 AM
98A4TQ's Avatar
Default Wastegate Actuator Assembly
does this part usually go bad and if it does would there be no boost?
Old Mar 12, 2007 | 02:18 AM
Flip's Avatar
Default RE: Wastegate Actuator Assembly
Wastegate actuators can go bad and if they do they can cause boost spikes or a complete loss of boost.
Old Mar 12, 2007 | 04:16 AM
auditech79's Avatar
True, but its rare. If you have a loss of boost check for any intake lines that may have come loose or are not connected which is a more likely cause.
Old Mar 12, 2007 | 03:59 PM
2k S4's Avatar
I would say, check the lines going to it, chances are you have a vacuum leak somewhere in the lines.
Old Mar 12, 2007 | 04:55 PM
98A4TQ's Avatar
thanks fellas I just bought a new DV and 10 ft of vacuum hose to start replacing it, I will also check all clamps for tightness.
Old Mar 12, 2007 | 06:31 PM
98A4TQ's Avatar
I found the hose that connects the airbox to the turbo loose at the air box side. I checked all the hoses i could from the top but i can't jack up the car anymore. Im gonna check the rest when my vacuum lines and DV arrive and I can put it on the lift at work. Thanks
james007d
Aug 26, 2011 10:16 PM
james007d
Aug 20, 2011 09:41 PM
Audi858
Feb 13, 2008 10:13 PM
98A4TQ
Mar 12, 2007 08:30 PM
petermcA4
Sep 10, 2005 12:43 PM
