Weird noises from Audi 80 2.6e
Hi, i`m a new proud Audi owner, however there is a noise on it that bugs me. Its a clicking noise when pulling away and when your parking, sounds like the c.v joint but its not from there.
Are there any common problems that occur with these models that i can check before i take it to a garage...?
Many thanks, Dan.
Many thanks, Dan.
Hi thanks for the reply,
The noise sounds like c.v joint gone but doesn't make any noise when turning. The noise is coming from the front passenger side and isnt a constant clicking it just makes a click when you pull away forward or reverse and occasionally it does it going over bumps. In answer to the question it does sound like its near the front wheel or on top of the suspension. All the ball joints, drop bar links/ track rod ends look good,
(could this be the engine mounts)
Many thanks for any help i can get,
Cheers, Dan
Cheers, Dan
