Whistling from flywheel/clutch
Old Apr 8, 2013 | 12:42 PM
sincityaudi's Avatar
Oh and according to the wordage you used it is the engine block breather valve.. Not the boost pressure control valve..
Old Apr 9, 2013 | 04:17 AM
nicbazwilly's Avatar
Cheers sincity. I have purchased a Boost Control Valve. Is this needed? I can probably take it back. To be honest I had no clue where it was to be fitted anyways. I will pick up a positive crankcase ventilation valve today, along with the turbo vent valve line. Hopefully I can spot this a little more easily.
Cheers again
Old Apr 9, 2013 | 04:40 AM
Ahh that makes more sense. Cheers i will order it now.
Old Apr 9, 2013 | 05:11 AM
Ok ive ordered the engine block breather but the turbo vent valve line is a part that teo of the distributors cant get hold of. If its easy enough i may as well change the boost control valve ( if i can find the mother!)
Old Apr 9, 2013 | 09:57 AM
It's not the easiest part to replace due to the location and the ear clamps that are used to secure the lines to the boost control solenoid... They don't go bad that often on the B7 A4's... I would return it if possible.. I will try to get you the part number for the turbo vent hose so you can try to cross reference it somewhere
Old Apr 15, 2013 | 08:14 AM
Just want to let you know, that it was indeed the Engine Block Breather. It took me 5 minutes to change and the whistling has stopped.
Ecstatic! Thanks for all your help Sincity.
I'll be back no doubt in the future.
Old Apr 16, 2013 | 10:18 AM
Glad I could help...
kraylon
Jun 8, 2007 07:20 AM
akoby9
May 9, 2007 04:14 AM
chivasreal
Sep 24, 2006 10:44 PM
audit2
Dec 9, 2005 12:10 PM
