Will not start after changing timing belt, water pump, and thermostat.
I just finished relaxing my timing belt, water pump and thermostat. I bought a kit that included the parts, plus new tensioner, serpentine belt, etc. After putting everything back together, I went to start the car and it cranks but will not fire up. Just a steady crank. Not even trying to fire up. Any ideas please?
Thanks
Thanks
Pull one of the plugs and leave it connected to the wire. Lay it on the engine making sure the metal base of the plug is touching metal on the engine. Spin it over. Look to see if there is spark on the spark plug. DO NOT hold it in your hand or touch it with your bare fingers while spinning the engine over unless you like being shocked. LOL
Are you sure you locked everything down at TDC (Top Dead Center) on the timing marks before removing the timing belt? All the timing marks line up before you tensioned the belt?
stokie7
07-05-2016 07:40 PM
brrman
03-10-2009 02:40 PM
