Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
1998 2.8 30v a4q cat help
Old Apr 8, 2012 | 05:31 PM
Faydes's Avatar
Default 1998 2.8 30v a4q cat help
Ok...so I am pretty sure I have a bad cat. however i cant pass emissions without getting a temp fix until i can afford the 1000$ to get it replaced.
currently i just stuck a doubled up spark plug non fouler in 1 of the o2 sensor's the passenger side one, it did not remove the cel(after taking off battery for 40 seconds to check.)
code its running is P0422 - Main Catalyst Efficiency Below Threshold (Bank 1)
does anybody have any idea what i can do for a cheap simple fix just to pass emissions till i can get it fixed. I cant afford to not have a plated car right now...no car=no job=no fixed cat, plus other problems.
any and all ideas just to get that CEL off so i can pass emissions would be greatly appreciated...cheaper the better.
Old Apr 8, 2012 | 11:23 PM
ImTheDevil's Avatar
Universal cats are less than $100 and probably about that much to have welded in by an exhaust shop. Then it's a permanent fix rather than temporary.
Old Apr 9, 2012 | 08:50 AM
Faydes's Avatar
getting a universal cat is not the answer, if i had the 200$ to get that done and welded id have the 200 more to just get the waiver. my job requires me to drive so no driving=no money =/
This is a very temporary fix, I am moving to houston soon where they have the lovely smog checks, so I can not just leave it like that.
although once that is fixed, and offtopic note i looked at your profile is the krautoparts led interior kit worth it? I was looking at some of the videos and it looked stunning
Old Apr 9, 2012 | 09:39 AM
ImTheDevil's Avatar
Ok then what budget are you working with? A dollar figure would help with options. What is telling you that you have a bad cat? Driving impressions, codes, etc? It may be something else.
As for the LEDs, the kit is absolutely worth it. I have all of them - plates, interior, and reverse lights. I love them. You will too.
Old Apr 10, 2012 | 07:34 AM
Faydes's Avatar
the code is, its the passenger side cat, do i have to run an obd2 clear after i install the non fouler? I just did that yesterday at an autozone but from what i have heard it resets the readiness flags
as for my budget its only around 50$ sadly =/, I am completely broke from this
and awesome as soon as i get this cat issue sorted, ill be getting a hold of that kit =)
dollarbil
Jul 11, 2011 03:28 AM
dollarbil
Jul 9, 2011 12:28 AM
captcaos2002
Mar 5, 2009 04:03 PM
s666ahd
Mar 21, 2007 09:45 AM
citamine
Jul 23, 2005 08:16 AM
