Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Boost Gauge and Intake Temp?
Old Jan 11, 2009 | 08:53 AM
a2thy's Avatar
Default Boost Gauge and Intake Temp?
I have somewhat of a chemistry question that's been on my mind for a while.
I know that a boost gauge measures the amount of airflow coming out of the turbo, and I know that cold air is more dense, meaning more combustion/power. What I DON'T know is whether or not the boost gauge accounts for intake manifold air temperature.
Let's just say for example a car does two trial runs with identical conditions and variables (the turbo is functioning in the exact same way during both runs). The only difference is in the intake air temperature. Would the boost gauge show the same amount of boost for both runs? or would it show more boost for the run with the colder air entering the intake manifold?
Old Jan 11, 2009 | 07:27 PM
Jc61990's Avatar
hmm not really sure. i would actually think it might show lower since how in the winter you some how loose a few psi of boost.
Old Jan 11, 2009 | 10:52 PM
cincyTT's Avatar
I'm make believe
The gauge shows PRESSURE, not airflow. A ko3 at 20psi flows far less than a gt35r at 20psi. You will make more power in the cooler air since the iat's are lower which allows for more psi and/or timing. The pressure will not change
Old Jan 13, 2009 | 09:19 AM
a2thy's Avatar
Ok, I understand that pressure and airflow are two different types of measurement. But will the colder air increase the pressure in the intake manifold?
zedea
Jan 18, 2013 03:11 PM
vtraudt
Feb 8, 2010 03:50 PM
swau
Oct 6, 2008 12:17 AM
neur0tic
May 21, 2007 01:25 PM
s4me
May 18, 2005 08:39 PM
