Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Idle problem
Old 01-20-2014, 11:09 AM
Peetwheel03's Avatar
Default Idle problem
Hello,
I'm having a problem with my car when it idles. It does not happen all the time but when it does the check engine light will flash several times. The codes show misfires on the cylinders. When you give it gas the problem goes away. I had it looked at and the mechanic said found a leaking internal pressure valve for crankcase breather. Has anybody had this problem and does anybody have a part number? The car is 2005 a4 1.8 base.
Thanks for your help
Old 02-01-2014, 09:27 PM
ImTheDevil's Avatar
First thing with idle problems is to check the condition and gap of your plugs. If it's been a good while that they've been in there, just replace them.
juha01
04-03-2014 01:56 PM
justinclarke
11-25-2010 04:03 PM
audiltr
04-24-2008 08:41 PM
cbailey_369
11-19-2007 04:00 PM
Quick Reply: Idle problem
