Point me to a DIY of woodgrain trim to silver trim please!
Simply like the title states, I just need some directions to do the trim job of converting the woodgrain into the silver. Also, does anyone know how I can fix a center console arm that was pulled out (the two clips/arms are not connecting and holding it in place) or where to buy a new one? Thanks for any help!
Here's the link to the page that shows you how to remove all of the wood trim:
http://www.audiworld.com/tech/int21.shtml
I used this procedure to remove mine when I painted it silver to match my car. It looks intimidating but it's easy and it'll take you all of about 40 minutes to remove all the trim. Are you looking to replace the wood trim with the OEM Audi metallic silver trim? If so, you might want to consider painting it instead - or getting the OEM stuff and doing the process shown in that link - they used aircraft stripper to create a brushed aluminum look. If you paint, make sure to sand it fairly smooth, prime with filler primer, spray a few coats, and then clearcoat if you want a high-gloss look.
Here's how mine came out - I didn't clearcoat or use filler primer, as I wanted a somewhat industrial finish to it, not a smooth finish as if it were fiberglassed.
irishaudi
Nov 25, 2013 05:35 AM
2001.5AUDIS4
May 1, 2010 10:37 PM
jccollins0726
Feb 15, 2010 04:27 PM
2000_S4_BITT
Feb 10, 2009 12:19 AM
410ThirtyValve
May 2, 2008 03:42 PM
