Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
FMIC VS Dual SMIC to keep boost on high RPM
Old Jun 27, 2010 | 01:11 AM
Soravia's Avatar
Question FMIC VS Dual SMIC to keep boost on high RPM
I'm researching into getting APR ECU upgrade and noticed that the reflash gives a lot of torque at low RPM but everything drops after 4,500 rpm. Without upgrading the K03 turbo charger (for quicker spool) I'm thinking of increasing the intercooler capacity to extend that torque to higher rpm, something closer to 6,000 rpm.
Most FMIC I read about needs cutting or removing the front bumper core, which to me is simply stupid to remove that protection. So I'm thinking dual side mount intercoolers and hopefully keeping the stock on too.
Will a Dual SMIC setup make me remove the smog equipment?
Are there difference in performance compared to a good FMIC? Will having dual SMIC make the turbo lag increase over FMIC of same capacity?
Which brands should I look for in decent price range?
Old Jun 27, 2010 | 10:36 AM
turbo kraut's Avatar
Tech Guru
dual side mounts have been discussed many of times.... if you don't have an bi-turbo car you don't need or won't benefit from dual sidemounts
and the only guys that are removing the core completly are bi turbo guys and people like mike hood, but with over 600 awhp you need that big of a core
my .02 get a fmic that fits, there are plenty out there, or upgrade your one side mount...
Old Jun 27, 2010 | 01:37 PM
jhuffman's Avatar
I don't think that the intercooler is your problem here. The k03 simply doesn't breath that well at high rpms. If you want to keep some high end torque above 5k rpms your going to need a k04.
Old Jun 28, 2010 | 09:48 PM
Tech Guru
i never had a problem with my car pulling from higher rpm's.... it actually pulled through all the rpm range.... the only time i had issues pulling was when i was in too high of a gear, and once you get the rpm's high enough walla
your problem with "pull" might be vac related
Old Jun 29, 2010 | 12:49 AM
Soravia's Avatar
My car is stock, and I don't get power out of it until I hit 3,500 rpm. Is it supposed to be like that from the factory?
It's got 100K on it and even after some working done as well as I could, the car runs just smooth, but not much power in terms of torque until I ht 3,500. Coming over from a Sentra SE-R Spec V. It really bothers me that I have to keep hitting high rpm and the car is still slower than stock RX-8.
Old Jun 29, 2010 | 04:59 PM
cincyTT's Avatar
I'm make believe
Originally Posted by jhuffman
+1
Its true that the ko3's are out of breath, but they also make a ton of heat. upgraded smics or a fmic will be a big help at keeping all that tq you make and keep timing from being pulled. Both will do the job, just depends on which you prefer. You can fit more cooling with a fmic than smics.
Old Jul 14, 2010 | 06:14 PM
R.A.I. Motorsport's Avatar
Former Sponsor
OP, I would get an upgraded SMIC and call it a day
carbon audi
Aug 30, 2012 03:34 AM
Mike-2ptzero
B7 Models
Jan 16, 2011 06:34 PM
warranty225cpe
Sep 16, 2009 12:14 AM
compmanben
Mar 24, 2008 05:32 PM
Matt_Iliketurbopull
Apr 25, 2007 07:12 AM
