Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Intercooler sizes?
Old Sep 19, 2007 | 02:22 AM
Bondga's Avatar
Default RE: Intercooler sizes?
ORIGINAL: kakarot
IC needes to be as big as needed. But, you can lower the size required to cool X amount of degrees by improving other factors. Like the restriction in the air system, Turbo efficiency, etc... Since the OEM turbos are quite efficient, a smaller IC is needed. If you desighn the system right, you can have a small IC.
As any heat exchanger, making the frontal area bigger will provide better cooling that by making the IC thicker.
If you want to do a custum one, maximize the frontal area, and then make thickness of the cooler only to alow the max CFM. Then you will actually get it very effcient IC and same or better response as OEM. Just have to get a book and use the formulas.
Ha... your a funny man. a k03 is about as efficient as semi with no wheels. anything over about 11psi and you run of the charts. and even at stock boost you bearly his peak effiecientcy of 72% and your only there for maybe 300 rpms
Old Sep 19, 2007 | 11:51 AM
cincyTT's Avatar
I'm make believe
Here you go, best to worse.
garrett
almost garrett
ok
better
ebayish
and tube and fin design
PCBOI808@HOTMAIL.COM
Sep 3, 2007 01:50 PM
