K03 Adjustable boost?
Products
It would relieve the control pressure from the N75 valve that’s supposed to open the waste gate.
Start with the valve closed. As you gradually open the valve, more and more of the control pressure will be bled off, keeping the waste gat closed. This would yield only limited boost increase because eventually the ECU will put the engine into limp mode. For more, you’ll need ECU modification (chip).
