1985 Honda Prelude Carb issue
Old Jan 26, 2011 | 02:21 PM
chocalotstarfish's Avatar
Super Moderator
Default 1985 Honda Prelude Carb issue
Cuz I'm to lazy to go anywhere else I'm hoping to see if anyone has experience with carbs...
it's a 1985 Prelude 1.8l with 60,000 miles. it's been sitting for about 7 years in a shop. I got it to run yey! BUT it only runs if the carbs are overflowing and dumping gas... (mounted sideways like a motorcycle) now if I get it where it should be where it's not dumping fuel it stutters and wont stay running. I can't find a carb rebuild kit for it, so any ideas?!?
Old Jan 26, 2011 | 03:30 PM
AWDaholic's Avatar
Senior Administrator
Didja check the timing? Points? Needing to dump fuel to get it to run sounds more like a timing issue... At least, it used to be, back when dinosaurs roamed the earth, and I first started piddling around with cars. Pull the rotor and see how clean it is. If its durty, hit it wit some steel-wool (so you don't scrape off any material using sandpaper). Inside the rotor-cap, too. Same deal.
I'm assuming you've pulled the plugs and checked teh gaps, already...
Old Jan 27, 2011 | 11:55 AM
Msnickbroderick's Avatar
Actual WIZARD
Gap to .28 if its chipped
Single carbed or dual? Maybe the crabs need syncing
Old Jan 27, 2011 | 02:26 PM
Super Moderator
Dual carbs. This has now been placed on hold again >.< This car is owned by my wifes uncle, same guy that co-owns the Miata. He wanted the miata as a dd so I was going to get the prelude working for autox. NOW he bought an 02 or 03 corolla for a dd! So I made the agreement to get the prelude running in exchange for the 2nd 1/2 of the miata. BUT he didn't say yes and he didn't say no! I finally after much searching found a carb rebuild kit for it, that comes with everything for both carbs
Old Jan 27, 2011 | 07:52 PM
bradtyler02's Avatar
Check the ricer section... this is the OT section... muuahahaha!
hsauer87
Feb 2, 2012 01:27 AM
Yentemad
Nov 15, 2007 02:15 PM
codeman583
Jan 9, 2007 03:51 AM
apg96
Mar 9, 2005 01:55 AM
apg96
Mar 1, 2005 11:01 PM
