Professional Racing NASCAR, Formula 1, Sprint, Rally & Off Road, SCCA Auto X, Le Mans, Pro Stock, Cart, Drag, IROC, etc.
alignment specs
Old May 6, 2007 | 09:17 PM
s4's Avatar
s4
Default alignment specs
Can someone recommend custom alignment specs for a 2001 S4 stock suspension and H&R swaybars for aggressive street / light track driving?
Old Sep 16, 2007 | 10:32 AM
Khardysius's Avatar
Default RE: alignment specs
I wish I could for you, but I'm a n00b when it comes to this stuff. I am curious though. I'd like to know what a good light street/heavy track setup would be... *hint* *hint*
Old Sep 16, 2007 | 01:17 PM
2k S4's Avatar
Stock setup you can't adjust much.
I would set the front toe to 0 & the rear to 0, if you know how to drive, & can really handle the car, set the back to 1/16 toe out, the car will rotate much better, but you loose some stability.
Really you need to upgrade the suspension, to remove some of the brake dive, & get some camber, & lower center of gravity.
GA2008A3
Mar 6, 2011 09:21 AM
p4sty
Sep 2, 2010 12:17 PM
norcalAUDIfan
Apr 30, 2008 09:59 PM
dale_gribble
Mar 26, 2008 01:43 PM
Ghaith
Nov 4, 2007 11:46 PM
